SprayCraft SP66 Professional Airbrush & Compressor Kit
- High performance airbrush and compressor kit
- Compact, oil-less and maintenance free compressor
- Gravity feed dual action airbrush
- Fluid control knob for easy adjustment
- Sprays light to heavy viscosity media
- Exceptional atomisation and accurate spray control
SprayCraft Acrylic Airbrush Paints - 6 Primary Colours x 32mlFrom £25.78 £21.48
JSP Force™ 8 and Force™ 10 - ABEK1 Filters - (Pkt 2)From £16.38 £13.65
JSP Force™ 8 Reusable Half Mask - Medium (Without Filters)From £15.18 £12.65
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)Special Price £12.38 £10.32 was £12.88 £10.73 Save £0.50 £0.42
The SprayCraft SP66 Airbrush & Compressor Kit is very easy to set up and even easier to use.
The maintenance free, oil-less air compressor is compact, portable and designed to neatly store away when not in use. It has a maximum working pressure of 50psi and is fully adjustable allowing traditional spraying at lower pressures, or spraying metallic paints at higher pressure.
The compressor’s case features an integral handy airbrush holder. The kit includes a SprayCraft SP65 gravity feed, dual-action, airbrush with 2m of braided hose. Gravity feed airbrushes require less air pressure as gravity helps draw the paint to the tip.
The SP65 airbrush comes with a 7cc fluid cup with lid and has a 0.35mm nozzle. It is suitable for standard and metallic colours.
