This neat, compact level features strong rare earth magnets to hold the level in place on a horizontal or vertical surface. These magnets are five times stronger than normal ferrite magnets, leaving your hands free for adjusting and aligning metal objects. This professional level allows you to take measurements on flat and round surfaces. The Stabila Pocket Pro Level has an aluminium body, precisely ground and with V-grooves on the base and side for pipe levelling. It is a professional quality spirit level, small enough to fit in your pocket or attached to a belt with the clip supplied. It’s an ideal size for levelling electrical back boxes and switches. Size 70 x 20 x 40mm, supplied in an ABS case with belt clip. Accuracy in normal position ±1mm / m.
