Thomas Flinn Concave & Convex Scraper Sets
From £9.28 £7.73
5 Reviews
  • 10 radii covered in each set
  • Concave for scraping spindles, chair legs etc
  • Convex scrapers for recesses on skirting boards etc
  • Sharpen with a standard burnisher
  • Two scrapers per set
  • Scraper 1 - 1/4", 3/8", 1/2", 3/4" and 5/8"
  • Scraper 2 - 7/8", 1", 1.1/8", 1.1/4" and 1.1/2"
Cabinet scrapers are used for finishing areas where fine shaving is necessary or scraping and cleaning off old paint and varnish. Traditional rectangular or gooseneck scrapers don't always do the trick especially when it comes to mouldings. These sets solve that problem, with a range of 10 radii available in each set; chances are there'll be a match for that last fiddly bit. Made from high quality CS80, each scraper is approximately 90mm diameter. The Concave scraper set contains 2 scrapers shaped specifically to scrape curved areas such as spindles, chair legs etc. The Convex scraper set contains 2 scrapers, shaped to scrape in recesses such as on skirting boards etc. These can be sharpened using a standard burnisher. Made in the UK.
The radii covered in each set:
4.00 5
