UJK Angle Adjustment Plate For Worktop Jigs
508620
508620
From £20.68 £17.23
4 Reviews
In Stock - Ready to dispatch
  • Accessory for the UJK Variable Angle Worktop Jig
  • Eliminates guesswork when cutting a joint to fit walls not quite square
  • Finds and sets the angle required, produces a perfectly matched joint
  • CNC machined from durable aluminium
  • Allow adjustments to produce accurate joints with internal angles between 85° to 95°
This accessory for the variable angle worktop jig takes the guesswork out of cutting a joint to fit walls that are not quite square. Using a standard jig, overcoming non-square walls is inaccurate and poor joints are often the result. The Angle Adjustment System eliminates this and produces a perfectly matched joint. CNC machined from durable aluminium, it fits into a slot already machined in the jig. Engraved markings on the variable angle worktop jig allow adjustments to change the angle of the male joint. It allows you to achieve accurate joints with internal angles between 85° to 95°. An added advantage of the Variable Angle Worktop Jig is that you can use it to find and set the angle required, resulting in a perfect joint.
British Made British Made
4.8 4
