USE CODE: BLACKFRIDAY TO SAVE 10% SITEWIDE*
Veritas Apron Planes
- Ideal for trim carpentry
- Scalloped sides allow for a comfortable firm grip
- Combined feed and lateral adjustment makes setting easy and accurate
Veritas Block Plane Sack - 190mm (7.1/2")Special Price £11.18 £9.32 was £13.98 £11.65 Save £2.80 £2.33
Axminster Professional Forged Flat Bar Clamp 200 x 80mmSpecial Price £11.23 £9.36 was £14.98 £12.48 Save £3.75 £3.12
This small, low angle block plane is ideal for trim carpentry. At 400g(14oz), it is half the weight of a standard block plane which is a big plus if you carry it in your apron pocket all day. The 140 x 44.5mm ductile cast iron body takes knocks in its stride. It has good hand feel; unique side wings allow a comfortable firm grip and provide stability for shooting. A combined feed and lateral adjustment mechanism makes setting easy and accurate. 12° bed angle, it comes with a lapped 25° bevel blade made of PM-V11 alloy steel. The blades are 2.5mm(0.098") thick (nearly 25% thicker than standard 2mm block plane blades) and 32mm wide.
EAN Barcode | 5052511076956 |
Nett Weight | 400 g (14oz) |
Plane Blade Width | 32 mm (1.1/4") |
Plane Sole Length | 140 mm |
