Veritas Bevel-Up Jointer Fence
475146
From £38.88 £32.40
  5. Half Star
3 Reviews
Low Stock - Ready to dispatch
  • Consistent and accurate square or bevelled edges
  • 280mm long anodised aluminium
  • Can be attached to either side of the plane
The Veritas Bevel-Up Jointer Fence enables you to shoot consistent and accurate square or bevelled edges with your Veritas bevel-up jointer. The 280mm long anodised aluminium fence can be attached to either side of the plane with the brass thumbscrews provided. A set screw can be adjusted to square the fence to the sole. As supplied, the 50mm tall guiding face can be used to plane edges perfectly square to the face of your workpiece. It can also be used to shoot angles less than 90° when a bevelled wooden guide is attached to the inside face of the fence.
4.70 3
