Veritas Detail Palm Planes
From £79.18 £65.98
  5. Half Star
13 Reviews
  • Great control for working fine detail
  • Bodies are just over 16mm wide by 38mm long
  • Investment-cast steel body with hardwood palm knob
  • Available in four versions: flat, concave, double convex and convex
  • A2 tool steel blade (1.5mm thick by 9.5mm wide)
  • Made in Canada
The Veritas Detail Palm Planes are small enough to get into tight spaces and allow great control for working fine detail. The 32mm diameter hardwood palm knob is height-adjustable for better in-hand registration or removable for work in tight spaces. The bodies are just over 16mm wide by 38mm long and the blades are 9.5mm wide. The investment-cast steel body has a 45° bed angle and a fixed mouth, and uses a brass retention screw to secure the included 30° bevel A2 tool steel blade (1.5mm thick by 9.5mm wide). Available in four versions: flat, concave, double convex and convex. The curved versions have a 13mm radius across the body; the double convex is curved with a 100mm radius along its length. Made in Canada.
4.70 13
