From £121.98 £101.65
Low Stock
  • For centred dowelling or doweling boards to a reference face
  • Micrometer clamp head can be set from 6 to 13mm from the centre line
  • Setting is positive and accurate to a few thousands of an inch
Customers Also Bought
This jig will not only do centred dowelling, but it will dowel boards of different thicknesses to one reference face; the assembly is perfectly flat on one side and all thickness variations are on the other side. This saves a lot of planing and scraping time. Using a dial, each micrometer clamp head can be set from 6mm(1/4") to 13mm(1/2") from the centre line to handle work from 13mm(1/2") to 25mm(1") thick. The setting is positive and accurate to a few thousandths of an inch. The movable clamp heads will grip work as small as 13mm(1/2") x 35mm(1.3/8"). With boards of constant thickness, you can set the jig for centred dowelling. For boards of uneven thickness, you set the heads for a constant set back from the reference face.
By using the tapered pin to register off the last hole drilled, you can quickly chain drill dowel holes for tabletops or panels. The movable bush carrier comes with 3 hardened steel bushings: 1/4", 8mm( 5/16"), and 3/8". Other sizes are available. All turnings are solid brass. Machined parts are anodised aluminium.
  • Movable clamp heads will grip work as small as 13mm x 35mm
  • Chain drill dowel holes using the tapered pin to register off the last hole drilled
  • Movable bushing carrier includes 3 hardened steel bushings: 1/4", 8mm (5/16"), and 3/8".
  • All aluminium parts anodised black, except the red bushing carrier
  • Register pins and clamping fittings are turned brass
    Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
    3.00 1
