Veritas Gent's Saws
From £60.88 £50.73
  5. Half Star
5 Reviews
  • 0.4mm thick high-carbon steel; cuts easily and stays true
  • Injection moulded back creates a solid one-piece blade/spine/mount assembly
  • Brass nut secures comfortable hardwood handle
Sharing the same, advanced materials as the Veritas dovetail and carcass saws, these Gent’s saws have 200mm long high-carbon steel blades just 0.4mm thick with 0.08mm of teeth set per side. The 20tpi ripsaw has teeth with a 14" rake angle and a 60° included angle. The teeth on the 22tpi crosscut saw have a rake angle of 15°, an included angle of 60° and alternating 15° bevel angles so that they sever rather than tear wood fibres. Both saws have a cut depth of 40mm. For strength and rigidity, the glass and stainless steel-filled polymer spine is moulded over the blade and handle stud. A brass nut secures the hardwood handle to the blade. Made in Canada.
4.60 5
