Veritas Small Crosscut Saw 16tpi - 235mm
211803
From £89.78 £74.82
6 Reviews
  • 0.5mm thick high-carbon steel with 16 teeth per 25mm (16tpi)
  • Injection moulded back creates a solid one-piece blade/spine/mount assembly
  • Saw cuts easily and stays true
  • Overall length 360mm (14.1/4")
The saw has a 235mm (9.1/4") long by 0.5mm thick high-carbon steel blade filed with 16 teeth per 25mm (16tpi). The teeth have 15° rake and bevel angles. The depth of cut is about 40mm. The back of this saw is injection moulded under high pressure onto the blade and stainless-steel handle-mounting bolt. This forms a solid one-piece blade/spine/mount assembly. The material used for the back incorporates stainless-steel powder for weight, glass fibre for stiffness, and a polymer resin binder. A brass nut fastener secures the comfortably shaped hardwood handle. The saw has great balance it cuts easily, stays true and the pistol grip helps make the saw feel like an extension of your arm. Overall length 360mm (14.1/4")
4.80 6
