Suitable for 115mm angle grinders, these discs are called Multi-Clean cleaning discs and are part of the Webrax range of products from Hermes designed to do just as they say. With a grain of silicon carbide on an abrasive web on a fibreglass backing pad they are suitable for removing rust, paint, lacquer, primer and filler as well as cleaning weld seams, sealant and adhesive residues and cleaning concrete surfaces. They have an anti-clog structure with minimal heat build up for long life and consistent surface finish. Available size 115mm, 22mm bore.
