In any workshop space is a premium and being able to move items not in use out of the way can create extra vital space. These quality pressed steel fixed castors can add mobility to benches and machinery.
The castors have a top plate fixing with slightly elongated fixing holes for screws or bolts. These solid nylon castoring wheels provide less rolling resistance and better load carrying capacity compared to a rubber tyred wheel. Although much longer lasting, solid nylon can be noisier and lack the cushioning effect of rubber.
The brake, when applied, prevents both the wheel from turning and the swivel from rotating. Universally useful items with applications in all sorts of areas.
Wheel diameter 75mm, width 25mm, overall height 97mm, top plate 65mm x 65mm, load capacity 70kg.
