Whitehill Steel Combihead Scribe and Rebate Block 96mm
950543
From £221.28 £184.40
3 Reviews
  • A true multifunction spindle moulder block
  • Used as a rebate block to produce exceptionally clean rebates
  • Will take most standard 40, 50 or 55mm moulding knives and limiters
  • Recessed for flush mounting with a countersunk screw
  • Material can be passed above the cutter block
  • A great choice for small to medium sized spindle moulders
  • Bore size 30mm
This 96mm steel Whitehill limited spindle moulder block is a true multi-function unit. Able to be used as a shear cut rebate head, a scribing head or as a moulding block using standard 40, 50 or 55mm x 4mm knives. The knife locating pins are spaced at 24mm and are 6mm in diameter. The rebate cutters are set at 3° for a gentle shear cut action. This block is fitted with four sided TCT spur cutters on the top edge to give perfectly square tenons. The block is designed to enable shaped scribing cutters or moulding knives to be fitted without removing the block from the machine. A reversible washer allows the block to be mounted with a conventional nut, or where the spindle has a tapped hole, flush mounting with the use of a countersunk head screw. The flush mounting of the cutter block will allow material to be passed over the top of the cutter head when deep rebating, profiling tenons etc. This Combihead is suitable for all small to medium sized spindle moulders. The block is supplied with rebating cutters and square scribing knives.
Customer AccountThe outline of a personCustomer BasketA shopping basket with a handleBritish MadeBritish Made logoBulk BuysA star with lots of pointsBusiness ServicesA building with a door at the frontCatalogueAxminster Tools CatalogueCategoriesView categoriesClick & CollectA shopping bag with a handleClockA clock face showing the timeThe CommunityAxminster Tools & Machinery Forum LogoCompareCompare productsDeliveryA van delivering parcelsPremium DeliveryA van delivering parcels fastCopyCopy to the clipboardEditEdit itemEmailAn envelopeEventbriteThe logo for the Eventbrite websiteExpandTwo arrows pulling away from each otherFacebookThe logo for FacebookFilterDots in a triangle shape pointing downfinanceA walletInstagramThe logo for InstagramiwocaPayiwocaPay payment logoLinkedInThe logo for LinkedInLocationA location markerMade in BritainMade in Britain logoMenuThree Horizontal lines stacked on top of each otherNotificationA notification bellPartnerBuy from our PartnersPay By FinanceNovuna Finance LogoPayPalPayPal payment service logoPayPal CreditPayPal credit payment service logoPhoneAn old style telephone receiverPinterestThe logo for PinterestPoint RightAn arrow in a circle pointing rightPrinterA printer, printing a piece of paperPrivatePadlockRating Star EmptyEmpty rating starFull Rating StarFull rating starRating Star HalfHalf rating starRemoveTwo lines in a x shapeReturnAn arrow in a circle pointing back to the startRewardsAxminster Tools RewardsSettingsView SettingsSortOne arrow pointing up, one arrow pointing downSpinA circle that spins to show that the page is loadingStockA circle which is coloured to show the current stock levelTagA clothing label tagTeachableThe Logo for TeachableTickA tick symbolTrade AccountSaving tag iconDeleteDeleteUnavailableA no entry signVideo PlayA Circle with a video play symbol insideWarrantyA screwdriver and a spanner in an x shapeWhatsAppThe logo for WhatsAppWishlistA heart symbolWood OutlineWood effectYouTubeThe logo for YouTube
5.00 3
