Woodcut Tools Pro-Forme 508mm(20") Spigot Handle
504447
From £96.98 £80.82
2 Reviews
Low Stock - Ready to dispatch
  • For use with the Woodcut Tools Pro-Forme hollowing system
  • Handles can be doubled up for greater length if required
  • Supplied as handle only
The 20" (508mm) spigot handle has a comfortable cushioned grip for long periods at the lathe and if required two handles can be fitted together for extra length if required. For use with the Woodcut Tools Pro-Forme hollowing system. Supplied as handle only.
The Woodcut Tools Pro-Forme hollowing system is one of the finest free-hand hollowing tools on the market. It has a hardened M2 high speed steel cutter that is open on the side to prevent clogging, which is common with other end grain/hollowing tools. Its adjustable safety gauge determines the depth of cut and prevents dig-ins. Each cutter is both re-sharpenable using a diamond file and replaceable to ensure a long working life from these tools.
5.00 2
