The Straight Zipbolt Slipfix is the perfect connector for attaching a handrail to the side of a newel post on a landing. The unique design offers several advantages over traditional methods. A hidden fixing within the joint, it has no need of covers or plugs to conceal its presence. You tighten the fixing using a 5mm hex bit in a cordless drill or a simple hex key. Once tightened it forms a very strong, safe joint. Coupled with the handy Zipbolt drilling jig, a handrail to newel post fixing is a cost effective and efficient solution.
Kit contains two bolts, two keyhole plates, two gear housings, screws and a 5mm hex bit allowing you to attach the handrail on each side of the post.
Cost effective, efficient solution, Unique design with distinct advantages
Hidden fixing, no need of covers or plugs, forms a very strong, safe joint
Perfect connector for handrail to newel post on a landing
Tightened with a 5mm hex bit in a cordless drill or simple hex key
