Hermes RB377 XY is a special mix of aluminium oxide grains. Closed coat and resin bonded, it provides high stock removal rates in the coarse grit range. The backing is hard wearing and tough polyester/cotton cloth, often used to make belts for sanding machines. RB377 XY is excellent for grinding metal and suitable for use on wood, metal and composites. 50m long roll, 102mm wide.
N.B. Please ensure that your dust extraction system is adequate and efficient, dust remaining on the abrasive will shorten it's life and reduce it's performance.
