Before You Start - Machinery
Principle 1: Accuracy doesn't stay set
Machines don’t hold perfect alignment forever. Over time, vibration, temperature changes, and regular use can cause:
- Fences to drift out of square
- Blades to fall slightly out of alignment
- Settings to shift without being obvious
These small changes often go unnoticed until cuts stop coming out cleanly or assemblies don’t fit as expected.
Before you start, take a moment to check that key reference points are still accurate.
One helpful tool: A digital angle gauge or setup block makes it quick and easy to confirm blade and table alignment with confidence.
Principle 2: Let the machine do the work
Forcing material through a machine is one of the most common causes of poor results. When feed pressure is too high:
- Cuts become rough or uneven
- Burn marks can appear
- The risk of kickback increases
A steady, controlled feed allows the cutter or blade to work as intended, producing a cleaner, safer result. Before you start, remind yourself to guide the material - not drive it.
One helpful tool: Push sticks or push blocks help maintain safe control and consistent pressure, especially on smaller pieces.
Principle 3: Clean machines work better
Dust and resin build-up affects more than just appearance. Over time, it can:
- Restrict movement
- Affect cut quality
- Increase strain on motors and components
Keeping machines clean helps them perform consistently and reduces the likelihood of unexpected issues. Before you start, check that key surfaces and moving parts are clear and free from build-up.
One helpful tool: A resin remover or machine cleaner helps keep tables, blades, and cutters working smoothly.
Principle 4: Comfort affects control
Fatigue builds faster than most people realise — especially around noise, dust, and repetitive machine use. When you’re uncomfortable or tired:
- Concentration drops
- Decisions become less precise
- Small mistakes become more likely
Before longer sessions, consider your environment and how you’re protecting yourself.
One helpful tool: Hearing protection and a dust mask help reduce fatigue and support better focus over time.
Final thoughts...
Working with machinery rarely goes wrong in a single moment. More often, it’s the result of small details being overlooked - alignment drifting, pressure increasing, or preparation being skipped.
Taking a little time before you start using machinery allows you to work with more control and confidence from the outset. These checks don’t slow you down - they help everything run more smoothly, safely, and predictably.
Whether you’re making quick cuts or working through a larger project, returning to these simple habits will always improve both the results you achieve and the experience of using the machines themselves.
Discover more...
If you've enjoyed reading this guide, why not take a look at some of our blogs?
