Axcaliber Ogee Panel Raising Cutter
- Create a classic looking ogee edge on raised panels
- Bearing guided, suitable for use on curved head panels
- Maximum speed of 12,000 rpm
- Precision made on multi axis CNC machines
- PTFE coating helps minimise resin build-up
- 1/2" shank
- This cutter is for use in router tables only
Ogee style panel raising cutter for use only in a router table with a maximum speed of 12,000rpm. The cutter is bearing guided and is suitable for use on curved head panels. Please note this cutter is for use in router tables only.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter | 76 mm (3") |
EAN Barcode | 5052511030521 |
H = Horizontal Depth of Cut | 31.75 mm (1.1/4") |
Shank Diameter | 1/2" (12.7 mm) |
X = Depth of Cut | 16 mm (5/8") |
