Axminster Workshop J-Type Veneer Roller
- For applying pressure to veneers, laminates etc.
- Hard nylon or stainless steel rollers
- Chamfered corners
Titebond Cold Press for Veneer - 3.8 litres (1 US Gall)From £46.98 £39.15
Four unique tools for applying pressure to veneers, laminates etc. Available with either hard nylon or stainless steel rollers in 40mm or 90mm widths (all rollers are 35mm diameter). The design, having an axle projection at only one side, gives the roller access into corners. All corners are chamfered so as not to mark the surface.
