Should they fail at any time due to a material or manufacturing defect, we will replace them free of charge. The Axminster Clamps range supports woodworking, engineering and general workshop use, delivering strength, accuracy and long‑term reliability. Lifetime Guarantee applies only to products displaying the Lifetime badge.
With glass fibre, reinforced jaws and a strong 20mm x 6mm steel bar, these clamps perform well. The biggest advantage is their simple, single-handed operation, leaving one hand free to steady the work. Simply squeezing the handles to operate the clamp, results in great control. They have non-slip inserts and the rear handle houses the release trigger. An easily operated locking mechanism on the fixed jaw, locks or unlocks the jaw to convert the clamp into a spreader. The jaw pads are tough and non-marring with a little ‘give’ to grip irregularly shaped work. All sizes – 100kg max clamping pressure
Should they fail at any time due to a material or manufacturing defect, we will replace them free of charge. This guarantee does not cover damage caused by misuse, modification or over‑clamping.
