Axminster Woodturning Long Hole Boring Bit Handle
107156
From £49.98 £41.65
1 Review
In Stock - Ready to dispatch
  • Fast accurate long hole boring on the lathe
  • E20 collet for secure lock, steel handle with rubber grip
  • Adjustable for accurate boring depth
The Axminster Woodturning long hole boring bit handle uses an ER20 collet to grip the 6.5mm shaft of the Evolution Series long hole boring bit (available separately, order part No. 504581). The handle is hollow, allowing the shaft of the bit to pass through. This useful feature enables you to set a predetermined boring depth, the handle making contact with the tailstock acts as a stop. This prevents the bit coming into contact with your counterbore drive.
Fitting an alternative ER20 collet, allows you to use the handle for tools with different shaft diameters.
British Made British Made
4.00 1
