Axminster Workshop AW318BT Benchtop Thicknesser - 230V
107676
From £339.98 £283.32
  5. Half Star
84 Reviews
In Stock - Ready to dispatch
  • HSS blades deliver 18,000 cuts/min, feed speed of 7m/min
  • Depth capacity up to 153mm, maximum width 318mm
  • Fold down table extensions with end rollers
The Axminster AW318BT benchtop thicknesser is compact and more than capable of fulfilling the needs of the enthusiastic woodworker.
Its powerful 1,800W motor quickly removes material up to 2.5mm thick with each pass. The two resharpenable HSS blades give 18,000 cuts per minute; this coupled with the feed speed of 7m/min results in an excellent ripple free finish. The maximum timber thickness is 153mm with a maximum width of 318mm.
The front and rear fold down table extensions with end rollers provide support for longer boards. A 50mm diameter dust hood allows connection to a vacuum extractor. The motor has overload protection with a reset circuit breaker, and the NVR switch prevents accidental startup.
The AW318BT benchtop thicknesser is highly portable and perfect for preparing both hard and soft woods for all kinds of projects. Supplied with tools and a blade setting jig.
Warranty Axminster Workshop 3 Year Guarantee
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage. (Excluding blades, abrasives, belts, filters/bags, other consumables.)
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee is void when used for business or educational purposes.
4.70 84
