For those wanting to turn their hand to slightly larger projects
Perfect for if you aim to turn larger projects, due to the increased capacity and mini bed extension, which extends the distance between the centres even further.
Please note that the lathe shown in this video features an earlier colour version. The current model has updated branding colours, but its design, features, and performance are identical.
Buy with confidence
Variable speed drive
The variable speed control unit enables you to adjust the speed to suit your project; delicate work, larger diameters or out of balance work pieces. The LED digital read-out of the spindle speed in RPM, makes it easier to stay in control.
Motor
A 750 watt universal DC motor with electronic speed control and 3 speed pulley provides full torque at all speeds.
Great capacity with potential to increase
With 510mm between centres (depending on centres fitted) and a bowl turning capacity of 355mm, many ambitious projects can be undertaken. Plus, with the supplied mini bed extension, you can increase your distance to 740mm. Image is shown with the bed extension attached.
Cast iron construction
The cast iron construction ensures stability and reliability. The bed is made from cast iron, helping to reduce vibration.
Supplied with Axminster Woodturning centres
The lathe is supplied with high quality stainless steel Four Prong Drive and Revolving Tailstock Centres; both designed and manufactured in Axminster, UK.
Perfect for...
The AD355WL is an ideal upgrade due to its increased capacity, or perfect for those more ambitious beginners who aim to turn larger projects.
Buy any Axminster Workshop lathe to claim these offers!
The AD355WL is perfect for those woodturners looking to move up from a smaller lathe, or as a first lathe for the more ambitious newcomer. With a capacity of 510mm between centres (depending on the centres fitted) and with a bowl turning capacity of 355mm, many ambitious projects can be undertaken. Use the Mini Bed Extension to increase your distance between centres to 740mm.
Made from grey cast iron, the stability and vibration absorbing properties will be much appreciated. Featuring a top quality DC brush motor, with variable speed, three belt ratios and reverse. It has a speed range to suit every project within its capacities. A spindle speed readout helps select the appropriate speed for the job.
The headstock has large bearings to support the spindle, a flip-up cover allows easy access to the multi-V belt for speed ratio changing. There is a 24-stop indexing facility, with a spring-loaded indent pin to hold the spindle into position. The spindle thread is M33 x 3.5, allowing many accessories to be fitted. It has a 2MT for centres.
Cam locks secure both the tailstock and tool rest holder, and both are easy to move along the bed.
Mounted on rubber feet and supplied with Axminster drive and tailstock centres, 200mm tool rest, 100mm faceplate and Axminster Workshop Mini Bed Extension.
Look for the icon and put your trust in Axminster Tools. You’ll get our comprehensive 3-year guarantee on all Axminster Workshop machines, which includes:
Year 1 – complete machinery coverage (excluding blades, abrasives, belts, filters/bags, other consumables).
Machine Classification
These products are designed and intended for those who require equipment for more regular, but not continuous, operation. They must be maintained and serviced in line with our schedule; otherwise guarantee may be void.
