Bosch BiM C-Tec Japanese Style Plunge Cut Blades (Starlock)
- Bi-metal longlife blade for hardwood and laminates
- Japanese style precision ground teeth
- For clean and precise cuts every time
- Offset for flush cutting
- 32mm wide, 50mm maximum cutting depth.
- Starlock fitting for maximum power transfer
- Sold singly
JSP SpringFit™ Fold Flat Valved Respirator FFP2 (Pkt 10)From £18.28 £15.23
Japanese style precision ground BiM teeth for clean and precise cuts every time, best suited to hardwood cutting. Bi-metal (BiM) for long life. Available in 32 mm widths, with a 50mm maximum cutting depth. Curved-Tec features a rounded cutting edge for smoother and more precise plunge cuts.
Suitable for Bosch, Makita and Fein (10mm) Multi-Tools and others using the Oscillating Interface System (OISâ„¢) or Starlock fitting for a secure fit and maximum power transfer.
| EAN Barcode | 3165140492485 |
Please note, respiratory items cannot be accepted for a refund once the seal is broken and the item has been worn.
