Bosch GST 150 BCE Jigsaw with Bow Handle
- Online exclusive
- Variable speed with pre-selection
- 4 stage pendulum stroke action, 150mm max cut depth
- Blower and dust extraction outlet
- Bosch SDS tool-less quick blade change
- Bend resistant sole plate for a firm work platform
- Supplied with case, blade, extraction set, glide shoe & splinter guard
Robust and powerful with an all metal gearbox for durability, the GST150 will cut up to 150mm in depth. Fitted with a 4 stage pendulum, constant electronics as well as variable speed trigger and speed dial, you have full control whatever the material you are cutting. Giving high cutting precision with a saw blade clamp system, blade changing is fast with the Bosch SDS keyless lever system. The aluminium sole plate is robust and bend-resistant for the toughest jobs; a dust blower keeps the blade cut line free of sawdust. Fitted with a removable dust extraction port for connection to a vacuum. Supplied in case with 1 x T144DP wood blade, splinter guard, extraction set and glide shoe for sole plate.
This applies to all professional blue power tools and measuring instruments from Bosch. The warranty excludes high-frequency tools, production cordless screwdrivers and pneumatic tools, supplied accessories, battery packs and chargers.
Registration required within four weeks of purchase. More information can be found on the Bosch warranty website and in the warranty conditions.
Blower | Standard Feature |
Corded or Cordless | Corded |
EAN Barcode | 3165140463638 |
Max Depth of Cut Steel | 10 mm |
Max Depth of Cut Wood | 150 mm |
Model | GST 150 BCE |
Motor Power | 780 W |
Nett Weight | 2.7 kg |
Pendulum Action | Standard Feature |
Plug Fitted | UK 3 pin plug |
Rating | Trade/Professional |
Sound Power Level LwA [Uncertainty K] | 94 dB(A) [3.0 dB] |
Sound Pressure Level LpA [Uncertainty K] | 83 dB(A) [3.0 dB] |
Stroke Length | 26 mm |
Stroke Rate | 500 - 3,100 /min |
Tilting Base | Standard Feature |
Vibration Cutting Sheet Metal [Uncertainty K] | 4.0 m/s² [1.5 m/s²] |
Vibration Cutting Wood [Uncertainty K] | 7.0 m/s² [1.5 m/s²] |
Voltage | 230 V |
