Easy Wood Tools Mid-Size Easy Hollowing™ Set 3-Piece
- Set of 3 Hollowers, hollow forms are as easy as 1, 2, 3
- Carbide cutting tips keep an edge many times longer than HSS
- Rectangular section shafts improve stability and minimise chatter
- No need to sharpen; simply rotate cutter to a fresh edge
- American Maple handle with copper ferrule for strength
- Easy Wood Tools are 100% made in the USA
Easy Wood Tools Easy Hollowers are designed to make turning hollow forms easier and safer and confidently. This set of all three will give you access from just-under-the-rim to deep unseen cavities. Hollowing is as Easy as 1 - 2 - 3.
The Mid-size Easy Hollower #1 is used to remove the bulk of the material from the middle of the hollow form or from the centre of medium to large bowls. It has a 12.7mm square section shaft providing stability when sitting on your lathe’s tool rest.
The #2 Mid-size Easy Hollower has a gently curved shaft allowing you to begin hollowing to the side and start undercutting.
The Mid-size #3 Easy Hollower has a pronounced curve, which allows you greater access when undercutting deep inside the hollow form. Both the #2 and #3 Hollowers have 9.5mm deep by 19mm wide rectangular section shafts providing excellent stability and giving a chatter-free reach of 100mm.
Easy Wood Tools’ replaceable carbide cutting tips keep an edge many, many times longer than HSS. When the edge eventually dulls; simply slacken the fixing screw and turn to a fresh edge.
The 355mm long handles are straight grained American Maple, with copper ferrules for strength. Their overall length is 572mm.
