Festool Battery & Charger Set 18V (4 x 4.0Ah)
- Get the power you need whenever and wherever
- 4 x 18V 4.0Ah compact Bluetooth enabled batteries
- DUO TCL 6 charger; charges 2 batteries at once
- SYS 3 T-LOC Systainer for easy transport and safe storage
- All the energy to get the job done
- Eliminates downtime due to depleted battery power
Get the power you need whenever or wherever you need it. Packed into a SYS 3 T-LOC Systainer are four 18V 4.0Ah Li-HighPower Compact battery packs. Alongside a DUO TCL 6 rapid charger.
Using lithium-ion high-power cell technology, these batteries are powerful enough for most applications. They are Bluetooth enabled for use with CLEANTEC mobile dust offering automatic start when the cordless tool is switched on (Bluetooth compatible dust extractor required).
The DUO quick-charger, charges two batteries simultaneously. It is suitable for all 10.8 V, 14.4 V and 18 V batteries (except BP-XS for CXS / TXS 10.8 V). A separate LED indicator at both charging ports.
This is plenty of energy to get the job done, being able to charge two batteries is a great advantage. It enables you to have two spare batteries ready ensuring you don’t get caught out. If you’re using tools that run on 36V (2 x 18V) then downtime due to depleted battery power isn’t going to be a problem. This represents an ideal addition to the Festool Basic variants or as additional battery packs for the workshop or construction sites.
The TCL 6 DUO checks battery's temperature and will not charge a battery that is too hot or cold. Sensors monitor temperature continually throughout the charging process to prolong the battery's life.
