Shaper Upcut Spiral 6.3 x 38mm Router Bit 1/4" Shank
- 6.35mm diameter with 38mm depth of cut
- Solid carbide composition stays sharp longer
- Great results in a wide variety of materials
- 1/4" shank
In Detail
The Shaper 6.35mm x 38mm (1/4"x 1.1/2") Upcut Spiral Bit instantly clears waste out of the cut. Made from solid carbide these cutters ensure a very clean and smooth fast action, greatly reducing tearout, leaving a smooth finish, and is extremely durable. Suitable for wood, man-made timber products, acrylics and non-ferrous metals. Cutting depth up to 1.1/2" in depth.
It has a 1/4" shank with the added benefit of a longer overall length and a longer cutting length for deeper passes and improved stability in deep channels.
N.B please ensure your workpiece is securely clamped when using upcut bits.
Overall Length: 75 mm (3")
Shank Diameter: 6,35 mm (1/4")
Cutter Diameter: 6,35 mm (1/4")
Cutter Length: 38 mm (1.1/2")
Geometry: Upcut, Spiral, 2 Flute
Material: Solid Carbide
D = Overall Diameter | 6.35 mm (1/4") |
EAN Barcode | 859790007375 |
X = Depth of Cut | 38 mm (1.1/2") |
International delivery is unavailable for this product.
