Trend T14EK Router (1/2")
108576
Low Price
Special Price £519.98 £433.32
was £569.98 £474.98 Save £50.00 £41.67
In Stock
  • 2,300W router for use hand held or fixed in a table
  • Supplied with remote router table safety switch
  • 2-in-1 height adjuster, use above or below a table
  • Variable speed control from 9,000 to 22,000rpm
  • 80mm plunge depth for deep cutting applications
  • Micro adjustable height and side fence as standard
  • Top-mount cyclone extraction efficiently clears the waste
  • Twin LEDs illuminate the area around the cutter
  • Phosphor-bronze bushes, ensure a smooth plunge
  • Automatic power shut-off prevents accidental start-up
  • Precision centring system for guide bush
  • Show More
The Trend T14EK is a router that comes without compromises.
This high-performance plunge router is designed to be used hand held or fixed in a router table.
The 2,300W motor delivers consistently high power, torque and speed, and features soft-start to prevent kick-back. The 80mm plunge depth opens up many opportunities for deep cutting applications. The seven-stage variable speed control from 9,000 to 22,000rpm, allows you to match the cutter diameter to the material for perfect results. The extra-wide 75mm base aperture can accommodate larger cutters, such as panel raisers, when used with a router table. This high-performance plunge router is designed to be used hand held or fixed in a router table. It is supplied with a Router Table Safety Switch, which does away with the need for a separate NVR switch when fixed in a table. A 2-in-1 plunge and router table height adjuster can be used from above or below the router, in both table and hand-held mode. Each 360° turn gives 1.0mm adjustment. The T14EK base configuration includes a standardised fixing pattern of holes that allow the T14Ek to be attached to a range of compatible tables, jigs and accessories.
When used hand held, phosphor-bronze bushes ensure a smooth plunge action. The auto-lock plunge lever allows you to easily and safely operate the plunge without releasing the handles. The ergonomic designed handles support a natural wrist position, reduce strain, and increase control.
For your essential safety the automatic power shut-off prevents the router from accidental start-up if the trigger lock-on switch is engaged, and the power supply is lost and restored or interrupted.
Twin LEDs illuminate the area around the cutter improving safety and accuracy in low-light situations, or the use of a jig is casting shadows.
A precision centring system uses a unique guide bush centring pin and adaptor plate to ensure perfect concentricity between cutter and guide bush for pinpoint accuracy with routing jigs.
The top-mount cyclone extraction features an enhanced dust adapter, which efficiently clears the waste. Its positioning ensures greater visibility and helps prevent extraction hoses from ‘snagging’.
Supplied with: side fence, remote power switch, 2-in1 height adjuster, 30mm guide bush, guide bush adaptor plate, 1/2" collet, centring pin, top-mount extractor adaptor, Cyclone dust adapter and storage case.
Warranty Trend 3 Year Warranty (Registration Required)
Trend offer an extended warranty of 3 years
Extended warranties are subject to registration. All registrations must be made within 28 days of purchase
Trend offer a collection service for Warranty claims made through Trend Customer Services (+44 1923 249911 / customerservices@trend-uk.com), but reserve the right to recover transportation costs for invalid claims.
For more information and to register your product visit the Trend website
Register now
4.80 6
