The Axminster Magnetic Hose Coupler Kits provide a quick and reliable way to connect a dust extraction hose to your workshop machinery. Designed to reduce the time spent changing between machines, the magnetic coupling creates a secure, self-aligning connection that simply snaps into place and releases just as easily when it's time to move on. The close-fitting design helps maintain efficient airflow, making it a practical addition to any dust extraction system where one extractor serves multiple machines.
This kit includes one 100mm male magnetic coupler and one 100mm female steel-ring coupler, both manufactured from durable workshop-grade plastic. Powerful rare-earth magnets provide a firm hold, while the steel ring ensures accurate alignment for a consistent connection every time. The magnetic coupler is typically fitted to the dust extraction hose, with the steel-ring coupler attached to the machine using either a short length of hose or a compatible rubber cuff, depending on your workshop layout.
EAN Barcode 5052511146994
