This Axminster Magnetic Hose Coupler Kit is designed to fit the hose side of your dust extraction system, providing a simple way to equip multiple extraction hoses with magnetic couplers. When used with compatible magnetic machine adaptors, it allows hoses to be connected and disconnected quickly, helping reduce downtime when moving between machines. The magnetic connection aligns automatically and provides a secure fit while allowing fast release when required.
The kit contains two 100mm male magnetic couplers and two retaining clips. Manufactured from durable workshop-grade plastic, the couplers are designed for everyday use in busy workshops and install easily onto compatible 100mm dust extraction hoses using the supplied clips. This makes it straightforward to prepare additional hoses or replacement hose assemblies for use within the same magnetic dust extraction system.
EAN Barcode 5052511147014
