The BORA Centipede 6-piece Riser Set is designed to quickly increase the working height of your Centipede workstand, raising it to a more comfortable 914mm (36) without affecting load capacity. Easy to install, the risers simply slot into the existing P-Tops, allowing you to adapt your workspace in seconds.
Ideal for use as a sawhorse or elevated jobsite bench, this set provides added flexibility whether you’re cutting, assembling or reviewing plans, helping improve comfort and efficiency across a range of tasks.
