The Easy Wood Tools Pro Easy Hollower™ #1 is the first tool in the Pro hollowing 1‑2‑3 system, designed for removing the bulk of interior waste from large hollow forms and from the centre of medium and large bowls.
As part of the Pro range, it offers the greatest leverage, reach, and stability, making it ideal for safely opening up deep forms and tackling substantial hollowing work with confidence.
The Pro Easy Hollower™ #1 features a solid carbide cutting tip and a 12.7mm × 19mm rectangular shaft that provides superior stiffness and tool‑rest stability during heavy waste removal.
The extra‑long 508mm American Maple handle delivers exceptional control and reduces fatigue when rough hollowing large pieces.
Like all Easy Wood Tools, it requires no sharpening—when a cutting edge dulls, simply rotate the cutter to a fresh one.
Hollower #1 is engineered for efficient, controlled bulk removal inside hollow forms.
The rectangular shaft improves reach and rigidity, minimising tool chatter while working deep in the vessel. When held parallel to the floor at centre height, the tool stays flat on the rest and helps reduce catches, even when cutting into unseen interior walls.
This tool begins shaping the internal cavity before refinement with Hollower #2 and final shaping with Hollower #3.
All Pro hollowers feature replaceable, long‑lasting carbide cutters that outperform HSS and require no sharpening.
Suitable for dry or green wood, acrylics, and resin, and 100% made in the USA.
What you get
Solid carbide cutter fitted as standard
508mm American Maple handle with copper ferrule
12.7mm × 19mm rectangular hollowing shaft
Shaft engraved with cutter reference number
Colour‑coded handle for quick tool identification
Specifications
Overall length: 812mm
Handle length: 508mm
Reach: ~200mm
Shaft profile: 12.7mm × 19mm rectangular
Optional upgrade
Negative rake cutters are available separately for smoother results on acrylics, polyester, resin, and tricky grain.
Replacement Tip Ci3 (109312)
