For power and accuracy, for easier, safer routing the Festool OF 1010 REBQ-Plus with LED Light, is in a class of its own. In a nutshell it is extremely versatile, excellently precise and very easy to handle.
The routing depth can be adjusted to the nearest tenth of a millimetre in seconds. The double-sided column clamp makes the router extremely torsionally rigid, guaranteeing perfect routing results.
With the rechargeable LED light ring around the working area, you can see the workpiece clearly and without any shadows. This is essential for achieving high accuracy in routing. This smart design lets you closely see the router cutter to improve your accuracy further.
This router allows easy one handed operation either with the Festool guide rail system or freehand.
Festool's Plug-It system with its detachable power cable enables the fast swapping of Festool tools or easy cable replacement. The new style Festool parallel side fence is easily adjustable for quick and precise alignment, as the central clamp features a fine adjuster and adjustable guidance jaws, free of any tools.
Supplied with 8mm and 1/4
