One charger for two battery packs. The TCL 6 DUO Rapid Charger allows you to charge two battery packs simultaneously. This is particularly useful for those cordless tools which run off 2 x 18V batteries (36V). It is beneficial to charge the packs at the same time to ensure they both are fully charged to the same level.
An additional benefit of the TCL 6 DUO is that you don’t need to hunt for a second socket in order to charge two batteries. Spare sockets can be at a premium on site. The TCL 6 DUO means you can get back to full power that much sooner.
Two separate LED indicators indicate the current charge status for each of the charging spaces. Suitable for virtually all battery packs from the 10.8 V, 14.4 V and 18 V classes, whether Li-HighPower Compact battery packs, the handy Ergo packs and all AIRSTREAM variants (with the exception of BP-XS for CXS/TXS 10.8 V).
The TCL 6 DUO checks battery's temperature and will not charge a battery that is too hot or cold. Sensors monitor temperature continually throughout the charging process to prolong the battery's life.
Charging current: 2 x 6,0 A
Input voltage: 230V
Weight: 1.50 kg
Please note: Festool batteries and battery chargers cannot be registered on Festool website as they automatically benefit from Warranty all-inclusive. For batteries and battery chargers purchased as accessories a copy of the invoice serves as proof.
Plug Fitted UK 3 pin plug
Manufacturer Part Number 577019
Web Attribute Set Chargers
EAN Barcode 4014549391198
