The Perform PD150BG 150mm Bench Grinder is a compact, light use grinder, well suited for general sharpening and light grinding tasks in the home workshop. It is also handy for shaping metal and deburring. Compact in size, it's easy to store away when not in use, whether under the bench, on a shelf or in a smaller workspace.
Designed for ease of use, the grinder features adjustable tool rests that can be moved to maintain the correct gap to the wheels as they wear. Clear eye shields are fitted to help protect against sparks and debris, while integrated spark arrestors deflect sparks and improve visibility during use.
Built with durability in mind, the PD150BG Bench Grinder combines cast iron, pressed steel and impact-resistant perspex in its construction. The 150mm wheels are powered by a smooth running 250W induction motor, delivering a wheel speed of 2,980rpm. Each wheel is 20mm wide, mounted on a 12.7mm spindle, offering versatility for a range of basic grinding applications. The wheels are 80g and 120g white wheels.
Measuring 350 x 235 x 235mm overall and weighing 6.5kg, the grinder is stable in use yet light enough to move and store when needed. The Perform PD150BG is an excellent choice for those looking for a reliable and accessible light use grinder.
