It is practically impossible to drill at a specific angle freehand. This carefully engineered drill guide helps you to drill at angles over a 110
The chuck guide assembly runs between twin steel guide bars. Bronze bushes ensure a smooth action between the assembly and guide bars. There is enough space between the bars to accommodate most drills. A precision-machined main shaft runs inside another bronze bush. The drive shaft is a 1/4
Included are UJK precision angle stops, specifically designed to allow you to set precise angles for your drilling tasks with the UJK Drill Guide, offering increased control and repeat accuracy in your work. These angle stops will allow you to work more efficiently by eliminating the need for manual measurements and guesswork, reducing errors and wasted materials. The precision angle stops are machined to ensure that an accurate 90° drilling position is achieved. They can also be adjusted to enable a precise, repeat stop at any angle and can be fitted on both sides of the quadrant.
The UJK drill guide is solid, and offers a great deal of flexibility. Bottom of drill chuck to underside of base is 230mm. Maximum Travel 210mm. Two pins, stored in the chuck guide assembly, when screwed into the base allow self centering drilling, for example when fitting a lock mortice into a door. The capacity when using self centering pins is 85mm. Optional 13mm chuck and centring vice available.
N.B. Not suitable for use with impact drivers.
