Experience reliable, long‑lasting lubrication with WD‑40 Lithium Grease. Its high‑viscosity formula delivers smooth performance and exceptional durability, even in demanding conditions. Engineered to withstand temperatures from ‑18°C to +145°C, this water‑resistant, heat‑resistant grease provides outstanding protection against rust and corrosion—helping your tools and components run smoothly for longer. The nozzle on the can allows for a wide spray, narrow straw spray and can be used up to 360 degrees in rotation.
Available Sizes 400 ml (aerosol)
EAN Barcode 5032227443907
Accessories
  • Roughneck 3 Piece Mini Wire Brush Set
    £5.78
  • WD‑40® Multi-Use with Flexible Straw 400ml WD‑40® Multi-Use with Flexible Straw 400ml
  • WD‑40® Specialist Dry Lubricant 400ml
  • WD‑40® High Performance Silicone Lubricant 400ml WD‑40® High Performance Silicone Lubricant 400ml
  • WD‑40® Fast Drying Contact Cleaner 400ml WD‑40® Fast Drying Contact Cleaner 400ml
  • GT 85 Machine Maintenance Spray 400ml GT 85 Machine Maintenance Spray 400ml
  • WD‑40® Multi Use with Smart Straw 500ml
  • WD‑40® Specialist Spray Grease 400ml WD‑40® Specialist Spray Grease 400ml
