ROJEK PK 315A Compact 1200mm Panel Saw - 230V
720861
Special Price £5,813.99 £4,844.99 was £6,459.98 £5,383.32 Save £645.99 £538.32
  1. Empty Star
  2. Empty Star
  3. Empty Star
  4. Empty Star
Write a review
Low Stock - Ready to dispatch
  • Enquire - contact us for a personalised quote
  • 1,200mm sliding table with cross cutting fence
  • 315mm diameter blade, 100mm depth of cut
  • Package includes ripping stop
  • Precision ground cast iron table
  • Scoring blade for splinter-free cuts
The design of the PK315A perfectly reflects ROJEK's commitment to quality and innovation. This machine includes many useful features generally only to be found on larger (more expensive) panel saws. The PK315A is amongst the best in its class with a rigid construction and ground cast iron table, guaranteeing a long service life. This European made machine offers any demanding professional workshop a high degree of accuracy coupled with ease of use and reliability.
The PK315A includes a very precise sliding table mounted on round chrome-vanadium steel bars for a super smooth operation. The large panel support is supported by a telescopic arm for rigidity exactly where needed. The panel support frame can take 2,400 x 1,200mm sheet material and includes a crosscut mitre fence, two flip stops and a cam operated clamp. The solid rip fence offers up to 800mm ripping width. The PK315A features a scoring saw with a separate 0.75kw motor for super clean cuts in faced boards. The main saw blade is 315mm, but the saw will take a larger diameter 350mm blade for increased depth of cut if required. This ready to buy package includes a ripping stop which aids the cutting of waney edge timber; this machine is also supplied with a 1ph 2.2kw motor.
The PK315A is a high quality European made machine, built to last. Contact our Business Team to discuss your requirements; call 03332 406406 or email [email protected].
Warranty 1 Year Warranty
