Trend Tool and Bit Cleaner - 532ml
- Spray on resin and pitch remover
- Provides rust and corrosion protection
- Industrial strength cleaner which increases tool life
- Lifts the dirt from the tool
- Non-flammable
- Supplied in pump action dispenser
WD-40 Multi-Use with Flexible Straw 400mlFrom £11.03 £9.19
Keeping your tools clean is essential to ensuring performance is at its best. This non-flammable, industrial strength cleaner is great for use on sawblades, router cutters, planer blades, files, wrenches, drill bits and more, to increase their tool life and keep them in perfect condition.
The Trend tool & bit cleaner is a brilliant lubricant, which provides rust and corrosion protection. Plus, it has properties which break the molecular bond to lift dirt from your tool, rather than eat away at the dirt which other cleaners do. Just spray on and wipe off for excellent results.
Supplied in an 532ml, easy pump action dispenser.
EAN Barcode | 5027654549605 |
Model | CLEAN/500 |
- Standard Delivery* - £4
