Axcaliber Milling Cutter with Top Bearing
952561
952561
- Axcaliber milling cutter with top bearing
- 1/2"(12.7mm) diameter with 8mm depth of cut
- PTFE coating helps minimise resin build-up
- 1/4" shank only
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
Show more
Show less
This Axcaliber milling cutter with a tight radius and top bearing is the perfect bit for sign making or many kinds of template or recessed work.
D = Overall Diameter | 12.7 mm (1/2") |
X = Depth of Cut | 8 mm (5/16") |
#AxminsterTools
