Axcaliber Ogee Panel Raising Cutter
666206
From £53.38 £44.48
3 Reviews
  • Buy 3 for £50.71 £42.26 each
  • Buy 6 for £48.04 £40.03 each
  • Buy 10 for £45.37 £37.81 each
  • Create a classic looking ogee edge on raised panels
  • Bearing guided, suitable for use on curved head panels
  • Maximum speed of 12,000 rpm
  • Precision made on multi axis CNC machines
  • High shear-cut angle for cleaner finish
  • PTFE coating helps minimise resin build-up
  • 1/2" shank
  • This cutter is for use in router tables only
Assurance with Axcaliber
- see how they're made
Ogee style panel raising cutter for use only in a router table with a maximum speed of 12,000rpm. The cutter is bearing guided and is suitable for use on curved head panels. Please note this cutter is for use in router tables only.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
5.00 3
