Axcaliber Round Over Cutters - 1/4" Shank
666035
666035
- Use with side fence in a router table
- Change the depth of cut to produce top or bottom quirk
- Cut from both faces of work for a bull nose edge
- Precision made on multi axis CNC machines
- PTFE coating helps minimise resin build-up
- 1/4" shank
Show more
Show less
These cutters are not bearing guided, they would need to be used with a side fence for hand held use or used inverted in a router table utilising the fence.
Axcaliber router cutters are high precision tooling, made using advanced technology on multi axis CNC machines. A high shear-cut angle gives them a smooth cutting action and results in a clean finish. The tips are diamond-ground micrograin tungsten carbide. PTFE coating minimises resin build-up.
D = Overall Diameter | 19 mm |
EAN Barcode | 5052511029143 |
R = Radius | 6.35 mm (1/4") |
X = Depth of Cut | 16 mm (5/8") |
