Axcaliber Single Flute Straight Cutters
AX807617
AX807617
- Single flute, small diameter cutters
- Ideal for stringing and inlay work
- Available in metric and imperial sizes
- Clean finish
- PTFE coating helps minimise resin build-up
- 1/4" shank
Axcaliber A5 Foam Router Cutter PresenterSpecial Price £4.30 £3.58 was £13.58 £11.32 Save £9.28 £7.73
Show more
Show less
A range of single flute 1/4"(6.35mm) shank cutters in metric and imperial sizes. Useful for inlays, stringing etc, a virtual mirror finish ensures a clean cut with a sharp edge whilst the diamond ground micrograin tungsten carbide tips ensure durability. Produced using advanced technology on up-to-the-minute multi axis CNC machinery. Shanks made from SAE4140 steel hardened to Rockwell 45RC, renowned for its hardness and strength. PTFE coating minimises resin build-up.
