Axminster Workshop M2 HSS Ground Drill Bits
- M2 grade Swedish HSS steel, in metric and imperial sizes
- Intended for general workshop and production use
- Deep flutes ensure good chip clearance 118° drill point
- Outside diameter tolerance H8 ISO 286, gives a close running fit
Axminster Professional 1.0-13 x 0.5mm TiN Coated HSS Drill Bit Set 25 PceFrom £103.48 £86.23
Our newly sourced HSS individual ground drill bits are made from quality Swedish M2 grade steel. They have been heavily tested at Axminster in our manufacturing department and are suitable for many materials up to and including hardened steels to HRC-30. Everyone has been so impressed they are now being used in manufacturing and on our engineering courses. These bits are ground from solid high speed steel bar and offer excellent chip clearance, rigidity and quality of cut. Perfect for home and production use they are available in a large range of metric and imperial sizes. Remember to use coolant when appropriate. Outside diameter tolerance of H8 within ISO 286. This gives a close running fit. Angle of the drill point is 118 degrees.
