Axminster Workshop 151F Spokeshave Flat Sole
- For cutting and shaping convex curves and chamfers
- Twin adjusting screws for depth and lateral adjustment
- Well rounded handles with thumb rests for comfort and control
- Ductile cast iron body with tough black enamel finish
The 151F Spokeshave Plane
Predominantly designed for work involving convex curves.
Blade
TThe blade is O1 steel, offering good edge retention and comes with a 25° bevel.
Body
Ductile cast iron body with a tough enamel finish.
Adjustable
Twin adjusting screws for depth and lateral adjustment.
Comfortable
Well-rounded handles with thumb rests for comfort and control.
This Axminster Workshop spokeshave features a flat sole. The 151F is designed for work involving convex curves. Producing, cutting, refining or making chamfers on external curved edges. The body is ductile cast iron with a tough enamel finish.
Our 151F spokeshave is based on an original first produced around 1913. The well rounded handles and thumb rests offer comfort and control when cutting. Twin knurled adjusting screws control both depth and lateral adjustment of the 54mm wide blade. This adjustment allows a very fine setting for delicate work. The blade is made from O1 steel, to ensure good edge retention and only requires honing before use.
EAN Barcode | 5052511131327 |
Model | 151F |
Nett Weight | 435 g (15oz) |
Overall Length | 250 mm |
Plane Blade Width | 54 mm (2.1/8") |
Sole Shape | Flat |
