Purchase an Axminster Workshop lathe to benefit from this unique offer in store! The introduction will give you an understanding of the machine, including set up and safe usage, as well as what tools, accessories and materials are suited to your projects - so you can get on with the important decisions of what to make!
Immerse yourself into the wonderful world of woodturning
Perfect for the beginner, these essential tools we'll make it easy to kickstart your woodturning journey.
Axminster Clubman SK80 Woodturning Chuck Package
Carefully put together with the beginner in mind, this unique starter kit gives you the most useful woodturning accessories. It is packaged in a convenient storage box giving you a safe place to store your tools when not in use.
Start spindle and bowl turning with this great value for money, set of six turning tools. Perfect for the beginner, the tools each come correctly ground and ready sharpened meaning you can start turning straight out the box!
A must-have for any budding woodturner. Recommended by our own Skill Centre Tutors, the Woodturning Foundation book and DVD walks you through 12 step-by-step simple and effective projects. Gradually building your skills and confidence to help you become an accomplished woodturner!
For complete peace of mind, we cover all parts and labour free of charge for three years.
The AW355WL is perfect for those woodturners looking to move up from a smaller lathe, or as a first lathe for the more ambitious newcomer. With a capacity of 510mm between centres (depending on the centres fitted) and with a bowl turning capacity of 355mm, many ambitious projects can be undertaken.
Made from grey cast iron, the stability and vibration absorbing properties will be much appreciated. Featuring a top quality DC brush motor, with variable speed, three belt ratios and reverse. It has a speed range to suit every project within its capacities. A spindle speed readout helps select the appropriate speed for the job.
The headstock has large bearings to support the spindle, a flip-up cover allows easy access to the multi-V belt for speed ratio changing. There is a 24-stop indexing facility, with a spring-loaded indent pin to hold the spindle into position. The spindle thread is M33 x 3.5, allowing many accessories to be fitted. It has a 2MT for centres.
Cam locks secure both the tailstock and tool rest holder, and both are easy to move along the bed.
Mounted on rubber feet and supplied with Axminster drive and tailstock centres, 200mm tool rest plus a 100mm faceplate.
Cast iron bed headstock and tailstock ensure minimal vibration
Powerful 750W DC motor, quiet and smooth operation
Variable speed with spindle speeds from 250-3,550rpm
Machine Classification
These products are designed and intended to be used in the Home Workshop for light work and not continuous use. They must be maintained and serviced in line with our schedule. Guarantee may be void when used for business or educational purposes.
