Axminster Workshop AW405FS Scroll Saw with Flexible Shaft
- 406mm throat allows larger projects
- Includes Flexible Shaft and accessory kit
- Variable speed for cutting various materials up to 50mm
More than a Scroll Saw the AW405FS is a hobby station, including a flexible shaft and accessory kit. Fitted with a powerful DC motor, the AW405FS features variable speed for cutting a wide variety of materials up to 50mm thick. The blade arms are independently pivoted giving a virtually straight up and down action, giving a better quality cut.
A generous 406mm throat and tilting table offers plenty of scope and the saw accepts pinned or plain end blades. The clamps are easily accessible for blade changing. A blower helps keep the cutting line clean and easily seen and a 35mm diameter dust port allows the scroll saw to be connected to a vacuum cleaner. The heavy cast iron base gives stability and ensures low vibration.
A truly useful bonus is the power take off with a flexible shaft, for adding fine detail to your work. The accessory kit includes a generous assortment of sanding, polishing, cutting and grinding bits. Perfectly suited to this craft.
The AW405FS also comes with a blower nozzle, eye guards and service tools. This Scroll Saw is a perfect machine on which to begin a fascinating hobby.
