Blum CLIP-TOP 100 deg.Hinge & Cruciform Mount Plate With Screws
717589
717589
- An all metal, nickel plated hinge, 100° opening angle
- Spring-closure mechanism
- Can be enhanced with BLUMOTION soft closer
- Tool-free door to cabinet assembly and removal
- 3-dimensional adjustment (with mounting plate)
- Height adjustment ± 2mm
- Supplied with a Nickel plated zinc die-cast cruciform with pre-mounted screws
Axcaliber 35mm TCT Boring Bit 12.7mm ShankSpecial Price £26.99 £22.49 was £35.98 £29.98 Save £8.99 £7.49
Show more
Show less
An all metal, nickel plated hinge. 100° opening angle and spring-closure mechanism. Tool-free door to cabinet assembly and removal plus 3-dimensional adjustment (with relevant mounting plate). Can be enhanced with BLUMOTION soft closer. Supplied with a nickel plated zinc die-cast cruciform with pre-mounted screws. Height adjustment ± 2mm.
#AxminsterTools
