Blum CLIP-TOP 110 deg. Soft Close Hinge & Mount Plate With Screws
717591
717591
- All metal, nickel plated hinge, 110° opening angle, spring-closure mechanism
- With integrated BLUMOTION soft close (with deactivation option)
- 3-dimensional adjustment (with mounting plate)
- Height adjustment ± 2mm
- Supplied with a Nickel plated zinc die-cast cruciform with pre-mounted screws
Show more
Show less
An all metal, nickel plated hinge with 110° opening angle and spring-closure mechanism. Tool free door to cabinet assembly and removal plus 3-dimensional adjustment (with relevant mounting plate). This hinge has integrated BLUMOTION soft close (with deactivation option) and a screw-on boss. Supplied with a nickel plated zinc die-cast cruciform with pre-mounted screws. Height adjustment ± 2mm.
#AxminsterTools
